Is there a batch way to copy the key to the comment field?. This is for the numerous WAV files I have where the key can't be written to that field.
geposted Mon 03 Apr 23 @ 3:25 pm
repeat_start keytocomm ? on & repeat_stop keytocomm : repeat_start keytocomm 50ms &
browsed_song 'comment' `get_browsed_song 'key'` &
browser_scroll +1 &
browser_scroll 'bottom' ?
nothing
- set the option "setTagsAuto" to yes (VirtualDJ Options)
- copy this code to an custom button
- open the folder and click the first title
- then start the repeat script
- test with a small file count
geposted Mon 03 Apr 23 @ 3:51 pm
just to note that will overwrite current comment.
There is the ability to append with different script.
geposted Mon 03 Apr 23 @ 4:07 pm
Wow, that was quick and thank you DennYo Beats, works perfectly. That's OK with me locodog.
geposted Mon 03 Apr 23 @ 4:14 pm
