Hi. I'm new to Virtual DJ. On CDJs and Rekordbox, when you play a track, it will also highlight in green songs that are the same key, or a 3rd or 5th above and below it. Does this feature also exist in Virtual DJ?
geposted Mon 03 Apr 23 @ 5:03 pm
Yes It does. In VDJ , All Related Keys to the song on the master deck have a Grey Tick Sign (✓) next to them.
geposted Mon 03 Apr 23 @ 9:03 pm
From the user manual;
geposted Mon 03 Apr 23 @ 11:20 pm
Got it. Thanks. I'll have to look and see if that checkmark is also visible on my SC6000's screens which is primarily where I'm looking.
geposted Tue 04 Apr 23 @ 3:58 pm
Another way would be to use a Color rule using KeyDiff Browser field.
Example ..
More Info .. https://www.virtualdj.com/manuals/virtualdj/interface/database/search/index.html#instantfilter
Example ..
geposted Tue 04 Apr 23 @ 6:22 pm
