I'm running windows 11 64gb of ram and a rtx 2070 ... what ever I do with my skin does not save as well as the loop setting open to turn loop back off and other settings I do in vdj
geposted Fri 21 Apr 23 @ 12:21 pm
It's on drive c ... how 🤔 do I check I just installed windows offline mode to
geposted Fri 21 Apr 23 @ 4:27 pm
Kurutoi wrote :
Where is the VDJ installed? Are there admin rights there
It would seem my folders save fine... tho I did have 2 drives die on me and everything is acting funny now
geposted Fri 21 Apr 23 @ 4:30 pm
I did another windows install hopefully this time everything works right
geposted Fri 21 Apr 23 @ 8:05 pm
Ok the windows install worked 💪 good thing I found out before the 2ed install that some hard drives went bad
geposted Mon 24 Apr 23 @ 7:54 am
