I'm on VDJ v2023 b7482 and have been trying to get my Denon SC3900 working in MIDI mode.
In MIDI mode, the platter doesn't spin up when I hit the Play/Pause button. Is there something special I need to do to start the unit playing in Vinyl mode? I see that there is a "PLATTER_ON" in the MIDI mapping, but there doesn't seem to be a button on the unit that can trigger it.
Thanks!
Thanks!
geposted Sun 23 Apr 23 @ 11:27 pm
PLATTER_ON is the command that starts the motor. You should not mess with it.
Just open settings, search for vinylMode and enable it on all decks.
geposted Mon 24 Apr 23 @ 11:55 am
I've tried with controls-->vinylMode set to "Yes" and "Per Decks" with both decks selected, but still no motion from the platter.
Anything else I should check or try?
geposted Mon 24 Apr 23 @ 8:56 pm
Does the platter spin without virtualdj? like playing CDs do they spin?
geposted Tue 25 Apr 23 @ 6:59 am
