Every time I try to Remove duplicates nothing happens.
The Title/Artist/Length/BPM/Key are the Exact same for some tracks but never get removed.
Hopefully this gets fixed soon as it is already a feature on the software.
Once this is fixed an (Auto Remove duplicates) would be nice to have.
geposted Mon 24 Apr 23 @ 9:50 am
Where do you try to remove duplicates?
On the top of my head I only remember it being a feature in the sidelist and the automix list
geposted Mon 24 Apr 23 @ 11:46 am
Actually the "Remove Duplicates" feature removes the SAME track if it appears twice inside a list.
By same track, it means the same full filename.
It does NOT remove tracks that have the same Metadata.
In fact if you copy the same file and put it inside 3 different folders and then drag those files inside the playlist window, they will not get removed when you use "Remove Duplicates"
They are not the same physical file (file path is different)
geposted Mon 24 Apr 23 @ 11:51 am
