Hi,
I wish to use CUEs, but I need to have control of how long the music have played after I have started on a CUE. When I start on a CUE the clock in the player is with reference to the total length of the song, not referring to when the music actually started playing.
Help anyone?
Help anyone?
geposted Tue 25 Apr 23 @ 12:31 pm
When the padpage is "Hotcues" , click then menu dot, and choose the display mode you wish.
Most likely you are looking for "Time Position" or "Time Left", one can also choose "Beats Left", among others.
See which you prefer. Don't you just love VDJ !
Manual:
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html
Can also be changed with Settings > Options > cueDisplay
with >> position, distance, beat, respectively.
Manual:
geposted Tue 25 Apr 23 @ 1:32 pm
Thank you IidejayII :-D
geposted Wed 03 May 23 @ 8:07 pm
