I have a problem with the Pitch config on my Denon prime 2. How do i get the sensivity from 36% to 10% ? / Kerry
geposted Mon 01 May 23 @ 2:53 pm
Shift + pitch bend buttons should change the pitch range, when the Prime 2 is used with VDJ
geposted Mon 01 May 23 @ 3:06 pm
