In windows 11 the "old" drivers for the reloop touch dont work with the touchscreen. I installed the latest drivers from the reloop website. when starting virtual DJ it states that the drivers need to be installed and if you click yes it will install the previous version that again wont work. so i get into a circle. any ideas someone? I can work with the screen but the touchscreen wont work..
geposted Thu 04 May 23 @ 5:27 am
Today I wake up and the display does not load where I find in options the voice sincere display only problems bought used
geposted Tue 19 Dec 23 @ 10:44 am
You might be better off posting in the Italian forum https://www.virtualdj.com/forums/8/Italian_Forum.html
geposted Tue 19 Dec 23 @ 6:53 pm
