Can someone explain to me what is meant by that?
- Update browser colors after moving color rule up or down in quick filter editor
geposted Fri 05 May 23 @ 2:45 pm
When you have multiple Color Rules .. https://www.virtualdj.com/manuals/virtualdj/interface/database/search/index.html#colorrules , if a Track matches more than 1 rule, the order of your rules matter, so you may need to re-order them. You do this by right-clicking on the cog icons and move up/down. Before the update, the change in order wasnt applying until you restart VDJ.
geposted Fri 05 May 23 @ 2:54 pm
OK, I got it. next question.
Is it possible that the browser view is updated in the order of my color filters.
geposted Fri 05 May 23 @ 3:35 pm
