Why should the NVIDIA T600 not capable for realtime Stems 2.0?
It's similar to an GTX 1650 4GB. It has the same Chip (TU117). The Memory is faster (GDDR6).
I own both GPU's and they are IMHO equal with realtime Stems 1.0.
Please support the T600 for Stems 2.0 realtime and not fallback to CPU separation.
geposted Sat 06 May 23 @ 2:20 pm
You can manually select it in the stemsGPU option and then untick the 'don't use GPU' box.
geposted Sat 06 May 23 @ 2:31 pm
Before I posted:
I have choosen the T600 manually in stemsGPU and all options in stemsFix are unticked in build 7547.
But VDJ uses the CPU and says stems speed: 1.7x - CPU (intel(R) Core I7-8700.
geposted Sat 06 May 23 @ 2:45 pm
In that case it's unfortunately not compatible.
(even though it's a similar card, the drivers or AI-capabilities might be slightly different)
geposted Sat 06 May 23 @ 3:43 pm
