Hi. I’m struggling to set the echo out effect to a pad. I’ve tried in the edit section of the pad itself and also on the remapping of my ddj800 but I can’t seem to get it to work. Any suggestions?
Thanks
Thanks
geposted Mon 08 May 23 @ 8:57 pm
I am having the same issue using the FLX10. Can someone please advice?
geposted Tue 09 May 23 @ 12:54 pm
Put it on a pad in a custom pad page, and assign that to one of the pad page modes?
If so
- The pad page editor is in the pad page dropdown
- The script needed on a pad in the custom/new pad page will be something like
padfx 'echo out' 50% 70% 60% 20%
... where you can of course change the values
- Assigning the pad page to a pad mode will be in the pad pages dropdown, while the controller is connected
The thing you don't want to do is change the controller mapping/scripting, because that will break all the other functions of the pads. Pad pages are important
If so
geposted Tue 09 May 23 @ 3:53 pm
