Hello all,
Some other bugs on the automix markers management :
1/ Impossible to see the automix markers on the right
turntable by using the window "BPM Adjust". On this
turntable, you can only see the markers if automix mode is
activated ; and in this case, you can only see the markers of
the current playing mode (fade, cut or mixtempo).
2/ On the left turntable, the shortcuts used to define the
position of the automix markers (function set_mixpoint) do
not affect the positions of the markers on the screen if the
window "Ajust Automix" is open. But when you close the
window, the positions are updated (so the shorcuts are
working well, it's only a display refresh problem). This problem
does not occur with the right turntable (ie if you use the
shortcut, the markers are immediately updated), except that,
with this right desk, you can only see and modify the markers
of the current automix playing mode.
3/ Impossible to memorize the modifications made in the
window "Adjust Automix" (modifications on the
flags "mixtempo" or "mix cut" for example). Even if you
reload the songs.
4/ The French title of the main window "Ajuste le BPM" is
written "Aduste le BPM" (it should be "j" instead of the "d").
5/ And I don't talk about the graphical display bugs on the
markers, because it's explained in another topic.
If I can help ....
DJ LARIOS
reload the songs.
If I can help ....
DJ LARIOS
geposted Sat 15 Nov 03 @ 7:27 pm
right,
my 1.07 reminds the changes, and presents them the next time I play a song... something wrong there, definitely.
1.08? ;-)
1.08? ;-)
geposted Sat 29 Nov 03 @ 11:21 pm
Not corrected in V1_08 ......
I find the Issue 1/ very big.
It's not clean to have things working on the left
desk and not working on the right one.
Regards,
DJ LARIOS
Regards,
DJ LARIOS
geposted Fri 26 Dec 03 @ 11:03 pm
Normally It'll be corrected in the next release.
Gwenn
Gwenn
geposted Mon 29 Dec 03 @ 9:28 am
Still not corrected......
Please, please, read this post !!
We are talking about a function that works on the left
desk and not on the right one !!
And since november ......
This bug is really a shame. And god knows how I love
this program !!
Regards,
DJ LARIOS
this program !!
Regards,
DJ LARIOS
geposted Sat 03 Apr 04 @ 5:20 pm
