Topic: Deleting Hot cues # 9 and up
Of course, I understand how to delete hotcues using the shift key to delete them, but how do I delete cues that are 9 and higher? I don't see a way to do this in the waveform display, don't see a way to get the UI/skin to show buttons higher than 8, and don't see a way to delete it from the Hotcue and PIO editor.
geposted Mon 15 May 23 @ 1:39 am
with the poi editor, click the cue in the left list, then click the trashcan
Thanks! I would have NEVER figured this out... :( You are a genius!
