Topic: Reloop doesn't work with backwards/smart
tslaysPRO InfinityMember since 2023
Just got my FLX10 and have the latest version installed.
When I press shift-4-beat-loop (which is reloop) it only works in forward mode.
Example: I have it on smart/backwards and I loop beat 5-8 and I go out of the loop and use reloop, it will throw me into beat 1-4 instead of 5-8. If I reload that again, I land before the first beat. It kind of cycles backwards.
This does not happen if I choose the more traditional forward loop. There everything works as expected. However, I would like to use smart mode AND reloop at the same time reliably.
Could someone look into this?
geposted Mon 15 May 23 @ 5:32 am
Does nobody has the same problem?
geposted Mon 22 May 23 @ 3:31 am
It will be fixed in the next update
geposted Mon 22 May 23 @ 5:04 am
Awesome! Keep up the great work VDJ Team!
geposted Mon 22 May 23 @ 5:21 am
Fixed in BUILD 7572 (2023-05-30).
You guys are so fast and reactive. Best money ever spent on a license!
geposted Mon 05 Jun 23 @ 2:56 am
