Topic: No MP3/USB output
I am running analogue devices through an American Audio VMS5. (Technics decks, Numark CD player and an Ipad,). I output to a Behringer Audio codec plugged into a laptop for broadcasting purposes through BUTT.
All my analogue devices perform as they should with volume levels showing on both the controller and the BUTT software. However when I switch to USB to play MP3's while they play, they do not output to the Audio codec and therefore cannot be broadcast.
Not sure if it is an ASIO setting, on my audio settings all 4 decks are set to the controller. When I try and switch them to ASIO the software locks up and I have to restart.
Any help would be appreciated.
geposted Mon 15 May 23 @ 2:19 pm
