I can't seem to get the ducking echo effect and the Merge Effect to work. Is this Merge Effect like the one in Rekordbox?
geposted Tue 16 May 23 @ 6:19 am
When you enable Ducking echo you arm it, and it then reacts based on what else you do
Like shown here:
No it's 4 pre-defined VDJ merged/stacked FX, designed for the FLX6, but also usable without the controller
LIke shown here:
geposted Tue 16 May 23 @ 10:00 am
