Maybe I'm just not seeing it, but, is there a knob or any kind of visual gain indicator on any skin in VDJ that shows where the volume for samples is currently set at?
I need to be able to visually see what the volume of the sample will be played at when triggered.
Thanks
DJ James
Thanks
DJ James
geposted Fri 19 May 23 @ 12:45 am
When using the sampler sideview in list mode, each sample has "volume line" that you can see, but also use to change the volume:
![](/img/382339/23390/Capture2.jpg)
And then if you enable the sample fx bar, you also get the sampler master volume to the right, marked in red above
But there are a few more things to think about regarding sampler volume
First of all the individual sample volumes may change with each triggering if you are using touch sensitive pads
And secondly, there are even more places than that to change sample volume. Like the gain setting on each sample
This may inspire you:
geposted Fri 19 May 23 @ 5:52 am
