Hi, how can I switch between the left deck 1 and 3 and the right deck 2 and 4 using the controller given in the topic, unless it is already set, and I do not know what combination you need to press, as it is not set, how to map that, for example, left shift pressed quickly twice moved me between two left decks and right shift pressed quickly twice moved me between the right decks.
Is Polish available for the latest version of Virtual DJ ?
geposted Mon 22 May 23 @ 1:06 pm
