I've got Automix set up to Fade Remove Silence, with a 1s gap between tracks. (-1.0 in the settings)
One track starts with vocal before the first beat, and it misses the first couple of words.
I've adjusted the Cue point to the very start of the track, but makes no difference.
If I set the automix gap to 2 seconds, then the track starts in the right place, but I don't want the 2s gap of silence.
Feels like a bug - you can't set a 1s gap in the GUI - only by adjusting the settings directly - I wonder if it's behaving differently as a result?
Any thoughts?
Edit - it's definitely a bug.
If I set the delay to 0s, the next track starts from the beginning.
If I set it to anywhere between 0 and 2s, it cuts into the start.
If I set it to 2s, it starts from the beginning.
Any thoughts?
geposted Wed 24 May 23 @ 12:59 pm
