Forum: Old versions
Topic: DDJSB3 deck change issue
I haver a DDJSB 3 that is not working as intended.
Whenever i start VDJ i can change decks using the controller, shortly after the program will not let me change decks anymore.
geposted Sun 28 May 23 @ 2:25 am
It's a known firmware issue.. you need to use the default Audio setup (Master output from SB3 sound card) for the hardware Decks swap to work.
