Topic: Playlist Order
Greetings:
When I arrange a playlist order by BPM, it affects the rest of the playlists. I don't want that, since I may have a playlists arranged on a certain order. How can I avoid VDJ8 changing all the playlists? Any options settings I need to update or change?
geposted Mon 05 Jun 23 @ 10:34 pm
Sorry Wicked, but the manual nor the video provided an answer. If you are referring to "reset order," then according to the manual and the video I have to that every time I change a specific playlist.....IT used to be that if you sorted a playlist by BPM or otherwise, the other playlists did not change.
with what build did it change ... i remember it always being this way sadly
Check what you have this set to in the options and try and toggle it.
keepSortOrder - Keep the sort order when you change folder
