From the same folder some songs loading fine, and some causing VDJ to crash when loading
geposted Wed 07 Jun 23 @ 7:18 pm
Could you share one file so we could test and reproduce it?
geposted Wed 07 Jun 23 @ 7:20 pm
There is a known issue in current Early Access which we are looking at but so far unable to reproduce.
Is it always the same Tracks that crash ?
Is it Tracks that have never been played/scanned before ?
For now, we recommend to revert to the Public Build 7555, but would help to provide some feedback as above before you do that.
geposted Wed 07 Jun 23 @ 7:41 pm
All of the tunes are not loading. When loads, VDJ freezes up and then shots down.
geposted Wed 07 Jun 23 @ 10:16 pm
I dont see any options to upload file
geposted Wed 07 Jun 23 @ 10:18 pm
All of the tunes worked fine before latest update, are not loading. When loads, VDJ freezes up and then shots down.
geposted Wed 07 Jun 23 @ 10:19 pm
upload to google drive, dropbox, or similar and share link and they can look at it
geposted Wed 07 Jun 23 @ 10:40 pm
Who do i share with or the address
geposted Wed 07 Jun 23 @ 10:49 pm
I have just tested the file and no crash on my side.
1) How do you load it? From Folder, from virtual folder, from filter, from desktop?
2) Do you see the status in the browser (maybe "computing stems deck i")?
3) Always with flac files?
+ questions from djdad:
4) Is it always the same Tracks that crash ?
5) Is it Tracks that have never been played/scanned before ?
geposted Thu 08 Jun 23 @ 6:15 am
I load from SD drive. Mp3. Flac. Wave. Doesn't matter, always worked fine . Now when load vdj freeze up for a moment and then crashes. Probably need to reinstall vdj
geposted Thu 08 Jun 23 @ 11:56 am
Can you try the following:
-Make sure to wait until the 'Starting Stems Engine' in the browser disappears before loading the first song
-Open %localappdata%\VirtualDJ\Cache\ and delete cache2.db and cache3.db then start VirtualDJ
geposted Thu 08 Jun 23 @ 12:00 pm
geposted Thu 08 Jun 23 @ 1:29 pm
Will try it. Thanks
geposted Thu 08 Jun 23 @ 1:31 pm
Thank you all . Problem solved. Downgraded to V7555. Dont know how did i get early release v7582 and i don't get why vdj would even have early beta releases available for downloads and upgrades.
geposted Thu 08 Jun 23 @ 4:03 pm
simple: you had early access updates enabled in Options - it doesn't enable itself - the user has to do it.
and early access updates aren't really a beta - they've already been tested - but they're released so users can test at home across a wider range of systems and set-ups to find issues that may have been missed in testing. the issue of songs loading and the software crashing is something that's happening to a few but not every user and the mare user feedback they can get - the faster they can solve any issues
geposted Thu 08 Jun 23 @ 7:09 pm
Hello, with reloop buddy when loading the track to any deck, the program closes immediately. With 7555 and earlier this problem does not occur
http://www.virtualdj.com/forums/252948/Spanish_Forum/Problemas_de_virtual_dj_build_7572_en_reloop_buddy__Al_cargar_un_track_sw_se_cierra.html
geposted Thu 08 Jun 23 @ 9:00 pm
Perfect , it's always simple when you know and guru like yourself. But for those who dont know, it not that simple
geposted Thu 08 Jun 23 @ 10:46 pm
Exact same problem here, with all my files. Deleted cache2.db and cache3.db and the problem remains. The only thing it solves is downgrade to v7555
geposted Thu 06 Jul 23 @ 11:15 pm
Would you mind trying if either 7561 or 7563 also work?
You can get them from https://www.virtualdj.com/download/build.html
geposted Fri 07 Jul 23 @ 3:51 am
I've installed both versions and both versions worked fine with no issues
geposted Fri 07 Jul 23 @ 12:29 pm
