Hi there. I am a lighting designer using the Line-in feature to capture audio coming from the band or dj on stage and send the realtime analyzed BPM to both Chauvet showxpress with OS2L and a WMX1 through Ableton Link.. (OS2L wouldn't let both controllers on the same computer share the IP/Port so I had to get creative)
Im curious if there is a way to restrict the analyzed BPM Range? Basically I'm wanting the BPM to always be analyzed at Half-time (i.e. 65=130, 70=140, 87=174, and so on..)
Thanks in advance for any tips!
geposted Sat 10 Jun 23 @ 4:52 am
