Topic: Stems calculation speed in CPU popup
I'm sure in a previous version when calculating stems you could hover over the CPU bar and it would display the speed of the current analysis.
That information seems to be gone now.
Have tried <stemsFixExtra>log</stemsFixExtra> as log and normal.
geposted Mon 12 Jun 23 @ 10:24 am
I get the Stems speed tooltip on CPU here, right after Starting Stems engine is done/gone.
In Status area , next to the Browser Search, you get just "Computing Stems Deck x" (and the progress when mouse is over) or more ?
I get the percentage in the status area (although truncated as I have a lot of filters) but nothing in the popup.
I calculate manually rather than automatically as its a 2019 Intel mac with a slow GPU running Windows 10
It is only shown for real-time calculation, not when precomputing
That explains that then. Thank you.
