Topic: Denon MC7000
So this is the controller I have and it has 4 "Assign" buttons up near the top, but I haven't figured out what they do, if anything. And while I can't think of anything I'd like to use them for, I'm curious if they are supposed to do something, and if not, generally how might I make use of them. I'm guessing I'd need to edit the skin that I'm using (default, Pro). But of course, that would depend on these buttons sending and receiving data from the software to begin with. At this point, I'm just curious what might be possible...
geposted Mon 12 Jun 23 @ 3:31 pm
Perfect. Mapping. I get it. Turn out the controller does send data... but not sure how it is used, but will check the docs....
