Forum: VirtualDJ Plugins
Topic: Flanger_TexZK not working in 64 bit version
Hello dear forum
I have a problem with the effect that I use at every party and for some reason it doesn't work in the 64 bit version
The exact effect name is
Flanger_TexZK
And I don't want replacements just that, does anyone have a solution for me? Thank you very much from the heart
By the way, if I roll the version back to 32 bit it works but I lose the ability to work with stems 2.0
geposted Wed 14 Jun 23 @ 11:02 am
32 bit effects don't work on 64 bit software.
You loose the ability to work with any stems feature. That's a 64 bit only feature
If you need a user created extension to work with 64-bit, the way is really to contact the guy who made it, and ask if he'll create a 64-bit version
