Hello.
So i've been using my Hercules DJ 4set controller for a while no and it's been working fine, but now all of a sudden my headphones stopped working with the controller.
I have my controller connected to the computer and i send my master through my Saffire 6 soundcard and my headphones through the Hercules Dj 4set the way i've always had it. But now when i try changing my headphones to go through my controller i get an error message saying "VirtualDJ - No sound card. * 3 - Hercules Dj 4set. Failed to initialize device"
Everything else works and i can control the decks and everything with the controller it's just the headphones that stopped working.
I tried the headphones and they work fine so they're not the problem.
I also tried to uninstall VirtualDj and reinstall the old build i had but the problem remains.
Also tried changing the usb port it was plugged in to just in case, still no change. Now im out of ideas, please help.
geposted Fri 16 Jun 23 @ 6:37 pm
Install and usr the Hercules asio drivers https://support.hercules.com/en/product/dj4set-en/
geposted Fri 16 Jun 23 @ 7:50 pm
I've done that too, didn't work
geposted Fri 16 Jun 23 @ 8:30 pm
