is there a function like Ctrl Z to undo an action just done? I think that would be important. Thanks
geposted Sun 18 Jun 23 @ 7:59 am
Unclear what you are wishing for?
What type of action?
Undo: Clone deck?
Undo loading of deck ?
Undo pitch change?
Undo change of FX in a slot?
Undo a change in Gain?
Undo a change in an EQ/stems setting?
Undo a change in the Settings configurations?
Undo an edit in the Pad Editor?
Undo an edit in the custom button Editor?
Undo an edit of a Mapping?
etc ?
possibly more details needed..
PS
+1
for Undo an edit in the Pad Editor?
geposted Sun 18 Jun 23 @ 6:06 pm
don't forget Undo that train wreck :-)
geposted Sun 18 Jun 23 @ 6:24 pm
I can't understand at this point in life why CNTRL+Z doesn't exist.
It has happened to me several times that I delete (Del) a track while trying to remove another, and I can't know which one I deleted.
It's something incredibly simple to implement, yet it's incomprehensible why it's not there.
geposted Thu 13 Feb 25 @ 3:31 am
In fact, I'm seriously considering switching programs and abandoning VDJ because of this.
I can't believe it's impossible to undo removing a track.
geposted Thu 13 Feb 25 @ 3:34 am
If you have an example of another DJ software that readily does what you are asking by default, please share it with us.
The devs have heard what you said however in other related posts - spamming more posts about the same topic doesn't help.
geposted Thu 13 Feb 25 @ 2:02 pm
