Topic: F11- Key (on Mac)
Hi!
I had a Mac with a Touchbar before.
Now I got my new one and sadly Apple ditched the Touchbar on the larger models.
So now I have to map my F-Keys properly.
(Yes, I've set the MacOS-System to use the F-Keys without using the "Fn"-Key)
Everything works fine, except of the F11-Key:
This one still performes the default Mac command (-> Showing the Desktop).
Since you developer guys managed to deactivate almost every default MacOS keyboard command inside VDJ (which is fantastic, by the way),
I was wondering if it is also possible for the F11-Key?
So it could be used as an map-able key on the keyboard.
geposted Sun 18 Jun 23 @ 12:01 pm
