Forum: VirtualDJ Plugins
Topic: Pan Effects
Is there a pan Effect that actually goes from right to left speaker that's it?
geposted Mon 19 Jun 23 @ 9:39 pm
Yes there is a pan fx under extensions
It of course requires you to be running everything in stereo ro work
Ok I don't understand is that a effect I can download? I think I'm running everything in stereo.
Yes. At least if you are running windows. Not sure about mac
But you can also simply map a knob to
master_balance
Ok thanks I’m gonna check it out. Yes I’m running Windows.
