Topic: nvidia card settings for stems
hh73PRO InfinityMember since 2006
should i have my driver settings on my rtx 4070 set to "quality" or "performance". if it even matters. in the sim games i play. i prefer quality. but if performance is better. then before a set ill just switch
geposted Tue 20 Jun 23 @ 8:23 am
I found there was no difference on the 4080. None of the settings affected VDJ or the stems calculation times in any meaningful way.
geposted Tue 20 Jun 23 @ 8:34 am
I have the 3060 and found the same, made no difference to VDJ, so would say just leave it as standard.
geposted Tue 20 Jun 23 @ 10:19 am
ok thanks.
geposted Tue 20 Jun 23 @ 10:50 am
For sim games, it's generally preferable to prioritize "quality" settings on your RTX 4070 driver settings.
geposted Mon 26 Feb 24 @ 6:20 pm
