Under: Support/Question & Answers/Software Installation/How do I delete or un-install VirtualDJ? (https://virtualdj.com/manuals/virtualdj/quickstart.html). Instead instructions are about quick start installation.
geposted Thu 22 Jun 23 @ 9:25 pm
Do it from control panel then delete database etc. when it asks. Simple as that.
geposted Thu 22 Jun 23 @ 9:52 pm
Thanks for the quick response, but what control panel?
geposted Thu 22 Jun 23 @ 10:30 pm
Oh you're Mac. Sorry about that. No clue whatsoever.
geposted Thu 22 Jun 23 @ 10:35 pm
Don't know what happened but this link ( https://virtualdj.com/manuals/virtualdj/quickstart.html ) does not show how to delete or un-install VirtualDJ. Can VDJ staff fix this, and instruct me how to delete VDJ?
geposted Sat 24 Jun 23 @ 6:05 pm
To uninstall an application on MacOS you simply drag it to the recycle bin.
If you also want to delete the library/database, you have to drag the ~/Documents/VirtualDJ folder to the recycle bin as well.
geposted Sun 25 Jun 23 @ 6:21 am
Thanks for all the help. Although VDJ staff needs to correct this.
geposted Tue 27 Jun 23 @ 12:45 am
VDJ stores stuff in THREE places.
1. The Applications folder. Find the app, and drag it to the trash.
2. User Documents folder. Same thing. Find the VDJ folder, and drag it to the trash.
3. User Library folder. This one is a bit more tricky: While in Finder, hold down the Option Key, point to the GO menu, and find the Library entry, and click on it. Once there, find the Application Support folder, open it, and then find the VirtualDJ folder. Drag it to the trash, empty the trash, it NOW its all gone.
geposted Fri 30 Jun 23 @ 4:56 pm
