Is it somehow possible to move/shift the Beatgrid with my controller?
I have an XDJ-XZ and in RB I can learn a combination of a button and turning the jog wheel. It would great if someone could explain how I can achieve this in VDJ.
Thank you!!
Thank you!!
geposted Mon 26 Jun 23 @ 3:50 am
There are a few keys in the mapping you need to modify (keys are coming depending on the Jog mode CD/Vinyl, when touched or not etc..)
JOG_CDJ and JOG_VINYL keys , are mapped as ... touchwheel
and JOG_TOUCH mapped as touchwheel_touch
Assuming that you map a button to toggle between CBG Move and normal Scratch, like..
toggle 'CBGMove'
you need to map the keys above as ...
JOG_CDJ and JOG_VINYL as .. var 'CBGMove' ? adjust_cbg : touchwheel
and JOG_TOUCH as.. var 'CBGMove' ? nothing : touchwheel_touch
toggle 'CBGMove'
geposted Mon 26 Jun 23 @ 2:43 pm
Thank you very much! I will try that! 🙂👍
geposted Tue 27 Jun 23 @ 11:14 am
Okay, I just wanted to edit the mapping just to find out that such a mapping for the XDJ-XZ in VDJ already exists. And it's the most intuitive mapping you would imagine: Shift and turning the outer jog wheel. :D
I'm sorry I haven't recognized this earlier.
Thanks again for your help though!
geposted Wed 28 Jun 23 @ 4:03 am
