The program virtualdj8.exe version 8.4.5874.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: c24
Start Time: 01d9aa0b363b8640
Termination Time: 7
Application Path: C:\Program Files (x86)\VirtualDJ\virtualdj8.exe
Report Id: f9e3944a-e0ae-4b23-a0cb-e74b5da05e01
Faulting package full name:
Faulting package-relative application ID:
Hang type: Unknown
Process ID: c24
Termination Time: 7
Hang type: Unknown
geposted Wed 28 Jun 23 @ 10:41 pm
Process ID: c24
Termination Time: 7
Hang type: Unknown
Process ID: c24
Termination Time: 7
Hang type: Unknown
System errors around the same time issue started:
The Windows Search service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 30000 milliseconds: Restart the service.
The BITS service failed to start. Error 0x80004015.
Process ID: c24
Termination Time: 7
Hang type: Unknown
I'm replacing the second hard drive winch was close to capacity
geposted Wed 28 Jun 23 @ 10:53 pm
Process ID: c24
Termination Time: 7
Hang type: Unknown
Process ID: c24
Termination Time: 7
Hang type: Unknown
OS Name Microsoft Windows 10 Pro
Version 10.0.19044 Build 19044
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-IIS4N87
System Manufacturer Dell Inc.
System Model G7 7790
System Type x64-based PC
System SKU 08EC
Processor Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2208 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date Dell Inc. 1.23.0, 2/13/2023
SMBIOS Version 3.2
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Product 0T3CD6
BaseBoard Version A00
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale United States
Hardware Abstraction Layer Version = "10.0.19041.2728"
User Name DESKTOP-IIS4N87\Blissful
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.8 GB
Available Physical Memory 8.35 GB
Total Virtual Memory 18.2 GB
Available Virtual Memory 8.45 GB
Page File Space 2.38 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
geposted Wed 28 Jun 23 @ 10:56 pm
you're using a build of the software that's 3 years old, has had MANY updates, fixes, improvements in performance and added features... and you're surprised you have issues with it???
turn on updates in Options, install the current public build, fully disable stems if your computer can't handle it, and turn off and disable all the unhelpful Dell 'assistant' built in bloatware. size of the hard drive has just about nothing to do with it and in any case is easily solved by using an external and then using VirtualDJ's file management to copy, move, and organize files
geposted Thu 29 Jun 23 @ 5:23 am
