hi! I have a pioneer ddj 1000 and obviously a vdj license
My back scratch stoped working . Also how do I set up to scratch in order to start playing
I will appreciate any help. thanks
#ddj1000
#ddj1000
geposted Sun 02 Jul 23 @ 11:21 pm
#ddj1000
#ddj1000
My back spin stoped working . Also how do I set up to scratch in order to start playing
#ddj1000
#ddj1000
geposted Sun 09 Jul 23 @ 5:01 pm
My back scratch stopped working
Perhaps SmartScratch is enabled ?
Dont quite understand.
If u mean Playback doesnt start right after you finished scratching, then you can increase the value of TouchWheelSpinThreshold setting to something like 1.0, 1.5 or even higher. Note that the higher you go the harder will be to perform backspins though.
geposted Sun 09 Jul 23 @ 5:08 pm
