Topic: How to use 10 minute test?
I'm trying to test a Hercules Inpulse 200 for 10 minutes like all the documentation says, but nothing seems to work.
I know the controller works, I tested it fine in Mixxx. It even detects the button presses in the mapping page of the settings, but nothing actually works. How do I enabled the 10 minute test in Virtual DJ?
geposted Sat 08 Jul 23 @ 4:00 am
If it's the Mk2 then it's not supported yet.
Support was released after I posted that.
Indeed , support for Inpulse 200MK2 has been just added to Build 7555 (or later)
You may have to restart VirtualDJ twice (silent update of Controllers patch)
Looks like it's up and working now, yes. Thanks for the replies!
