from down load from page & VDj..
geposted Sun 09 Jul 23 @ 7:56 am
ran just fine when i updated it
geposted Sun 09 Jul 23 @ 8:03 am
In the last few minutes, I've updated my Backup Intel MacBook Pro which is Bootcamped with Windows 10.
I updated the macOS version of VirtualDJ with build b7600 with no issues.
I then Booted into the Windows partition and updated Windows first. Then I updated the Windows version of VirtualDJ with build b7600 also with no issues. I connected my external HD containing music & videos and everything is working normally as expected.
My Systems Specs;
Main - M1 MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.4.1, VirtualDJ Early Access v2023-m b7600 .
Backup - MacBook Pro 15-inch 2018 (Touch Bar), 2.9 GHz Intel Core i7, 16gb 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Ventura 13.4.1, 500gb SSD. NTFS for Windows installed. VirtualDJ Early Access v2023-i b7600.
+ Bootcamped with Windows 10 Pro Vers. 22H2 x64bit. VirtualDJ Early Access 2023-i b7600.
External WD Passport Ultra 2Tb HD formatted exFat containing Music & Video databases.
Controllers - Denon MC7000, Denon MC6000 Mk2.
My Systems Specs;
geposted Sun 09 Jul 23 @ 11:24 pm
It appears on some macs the update process indeed fails.
Manually installing either the current stable from https://virtualdj.com/download/ or the current Early Access build from https://virtualdj.com/download/build.html should work fine though
geposted Mon 10 Jul 23 @ 4:28 am
