How do you set up the sound effects so you can click it once and the sound effect continues till its conclusion, as opposed to having to keep my hand pressing the mouse to get to the end of the sound effect example explosion effect.
Thank in advance
Thank in advance
geposted Sun 09 Jul 23 @ 3:09 pm
It's actually samples
You need to change your sample triggering mode to toggle on/off
geposted Sun 09 Jul 23 @ 3:23 pm
Thanks how do you change a Triger method ?
geposted Sun 09 Jul 23 @ 3:32 pm
Trigger mode Nr 2. https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/sampler.html
You also need to set the Sample to Drop mode (Nr. 9) in Sample Editor .. https://virtualdj.com/manuals/virtualdj/editors/sampleeditor.html
geposted Sun 09 Jul 23 @ 3:54 pm
Thanks guys keep spinning :)
geposted Sun 09 Jul 23 @ 5:35 pm
