Hey does anyone know if on the prime 4 you can have the stems set to all 4 channels of the eqs rather than inner and outer so you could potentially adjust stems via the eq knobs on all 4 channels at once and not have any conventional eqs present.
geposted Tue 18 Jul 23 @ 7:39 am
Yes, you can have eq knobs control stems on all four channels
geposted Tue 18 Jul 23 @ 8:49 am
Thank you. 👍🏻
geposted Tue 18 Jul 23 @ 9:14 am
Works with all Controllers ;-)
geposted Tue 18 Jul 23 @ 1:07 pm
yep. any midi controller with pads can uses stems. even my mc6000mk2 while now pads, you can use the mouse to click on the stems. granted your pc is powerful engough. stems love vram and a decent gpu. and at least a fast i5 or higher.
geposted Wed 19 Jul 23 @ 9:25 am
When You have a Controller Without Pads , You can also use Stems with Equalizers ;-)
geposted Wed 19 Jul 23 @ 9:15 pm
