Hi - wondering if there is a way to create a custom browser column for a specified folder within a path?
My music is all within 3 main folders, I would like for the custom column to show which of the 3 folders the track is in, exclusing the prefix which is all the same for the folders since it will take up too much room in the browser view.
For example, the full paths are as follows. Can I only extract Folder A, B, or C as the column data for each track?
c:\users\Matt\GigMusic\Folder A
c:\users\Matt\GigMusic\Folder B
c:\users\Matt\GigMusic\Folder C
geposted Wed 19 Jul 23 @ 12:35 pm
The only way I can think is to employ filters.
Either quick filters, or normal filters.
Not exactly what you're looking for, but it should do the trick
geposted Wed 19 Jul 23 @ 1:59 pm
or use a lesser used tag and fill the data yourself [with a batch script]
geposted Wed 19 Jul 23 @ 2:35 pm
thanks for the suggestions. I guess there also no way to have a path alias?
Essentially set the full path name with an alias and VDJ does an on the fly search and replace in the browser?
geposted Wed 19 Jul 23 @ 8:06 pm
