Forum: VirtualDJ Plugins
Topic: Sounds laser
Does Virtual dj offer different laser Dj sound effects? Where can I get some for free?
geposted Mon 24 Jul 23 @ 3:51 am
I assume you mean samples?
Yes there are probably some in the sample packs under extensions
Personally I usually get my weird samples from freesound.org, and then load them as samples in VDJ (and adjust the gain)
Thanks y’all!
Yes I meant samples thanks for the correction.
