Topic: iCloud
I took off my iCloud off of my computer and my virtual DJ database went away! Everything went away? I can every thing on my iCloud so reconnected the iCloud but it didn’t return bck even though I can see my files!
Please help.
Also there is No Virtual DJ folder on the computer just the cloud.
geposted Wed 26 Jul 23 @ 7:24 am
If you re-installed or run VirtualDJ while the home folder was missing, then the new default location for it is inside Application Support Data.
In order to open the folder in it's new location, start VirtualDJ, open settings, click on Options tab and then click the small cog icon on the bottom right side of the settings window.
This should open a new Finder window with the new VirtualDJ home folder selected.
Just move the files from the old folder inside this one.
