Topic: LINE IN SETTINGS
hello everyone just a quick question i have virtual dj 8 and DDJ SR2 need to use LINE input but it wont work maybe theres a setting in virtual dj that i can do to enable LINE IN.
thanks in advance.
geposted Wed 26 Jul 23 @ 7:57 am
If you want to use the input in the VDJ software, you need to have it a part of the inputs in your audio config
After that you need to pick which channel/deck to send the audio to, by enabling it as an input on that deck
Then you can controll the volume and so on using that deck
