Topic: set a button for stem
I am trying to config the stems on a pad button
deck right stem_pad vocal
is this correct?
geposted Mon 07 Aug 23 @ 9:20 pm
Normally you dont need to define the deck. It will be automatically added when called from a Deck button/pad.
So just stem_pad 'vocal' will do
Thank you
it is working now
yes but I want to put on my akay APC mini I have tried and if I don't put left deck or right is doing randomly
1.
If you are looking to activate a specifc action to a specific deck then just preceed the command with 'deck' and it's number.
2.
Alternatively, you can replace the deck number with the side names - left or right.
(I test it with custom button not with a controller.)
Try:
deck left stem_pad vocal
wollerosekauf wrote :
1.
2.
Try:
Yes, it is working now. thanks
now, extra question is how to export to a second computer all the settings I am doing on the first?
It will be in the settingx.xml in the VDJ home folder, of if moxe cplex like pad pages or controller re-mapping, in the appropriate sub folder of the home folder
I usually just copy all of it to the new laptop
You can do this either manually or by using the backup / restore options in VDJ
