Topic: Automatic Cloudlist query
Am I missing something?
For Automatic Cloudlist the manual says "once you set up an automatic CloudList, you just go on with your gigs, and the CloudList will always reflect your own top40 charts" ... but it doesn't auto populate.
Do I have to manually send each set I play to the Cloudlist?
If so could sombody change the name to "Not At All Automatic Cloudlist".
If I am missing some step or threshold can someone please explain.
Many thanks.
geposted Mon 14 Aug 23 @ 12:05 pm
I can confirm, same behaviour for me.
I just created a test list under my profile here, set it to automatic, then played some tracks in VDJ.
The cloudlist remained empty. Mind you, the description does mention top 20 and top 40. I only played five tracks just for testing.
Maybe it requires X number of tracks before it writes, or is set to update only every X days or weeks....in which case this should be mentioned.
I've just revisited the cloudlist after doing two hours of streaming on both Monday night and Tuesday night.
The cloudlist remains empty.
Looks like indeed something not working correctly, we'll check
Still not populating auto playlist.
Any progress on this? Cloudlist still not populating.
Is anybody home?
It has indeed not been fixed yet
Are we nearly there yet?
Still not populating...
The auto cloudlist is still broken. Not populating.
Is this ever going to be fixed?
should be fixed.
(note: only "real" sessions, with at least 10 tracks played, are used for dynamic cloudlists. just messing around quickly with files at home will not be used to populate dynamic cloudlists)
I'm doing regular three hour streams twice a week, not "messing around".
Thanks for the info.
