Hy Guys,
I have problem with connecion to server.
I ´ve buyed pro licence but if I try to write my email adress to connect with the server, the system can´t find server.
What is the problem?
Can anyone of You help me with this?
THX!
THX!
geposted Fri 18 Aug 23 @ 7:01 am
It's normally because the laptop has had a cracked version of VDJ installed at some point
That changes the network config as part of the crack, so the license servers can't be found
Here is how to fix it:
https://virtualdj.com/wiki/checkinghostsfile.html
geposted Fri 18 Aug 23 @ 9:13 am
Thank You so much klausmogensen.
You really helped me.
geposted Sat 19 Aug 23 @ 11:48 am
