I BOUGHT THE PROGRAM HOME PLUS FOR A NUMARK NS6 AND IS NOT RECOGNIZING THE UNIT. In the license page it does say the I have the license. NEED HELP!!
geposted Fri 18 Aug 23 @ 3:52 pm
It appears that you have purchased several Home Plus licenses for controllers (Mixtrack, Mixtrack 3, DDJ-SR and Mixtrack Pro FX) but not for the Numark NS6.
Either you need to purchase the correct Home Plus license for the NS6, or consider purchasing the Pro Infinity which will allow you to unlock and use ALL the supported controllers you have or may buy in the future.
geposted Sat 19 Aug 23 @ 12:41 am
