My app is missing the airhorn on my app
geposted Fri 25 Aug 23 @ 3:15 pm
this is NOT a bad thing! it's the most annoying overplayed and cheesy audio sampler in the history of dj'ing and the first thing i deleted from the software when it was there.
but you can always open Options and go to the Extensions tab - look in Samples - audio effects and scroll down to find the default samples
geposted Fri 25 Aug 23 @ 9:55 pm
