I am having issues with Virtual dj not connecting to my c drive on my laptop. Its only recently started happening and i have lost all my saved cue points etc. Anyone have any idea why this would be? I have virtual dj infinity pro license
geposted Sat 26 Aug 23 @ 11:55 am
close vdj & then check task manager for any vdj processes and kill them if you find any.
geposted Sat 26 Aug 23 @ 12:06 pm
Checked this and no processes running for vdj. Any other ideas much appreciated
geposted Sat 26 Aug 23 @ 12:18 pm
did you set it to ignore it in options?
geposted Sat 26 Aug 23 @ 3:35 pm
Does this help? Nothing set to ignore
geposted Sun 10 Sep 23 @ 10:08 am
It's not a problem with access to the C drive, as you can run VirtualDJ. As the message says, there seems to be an issue with the database. VDJ is displaying tracks in the browser though, so it has clearly read something.
Do you have tracks on the internal drive plus an external drive?
I just noticed, the list of folders on the left looks very confused/duplicated - from what I can see of the blurry image.
By the way, you can use the 'print screen' key on your computer to grab images of the screen. You don't need to take pictures of it with your phone :-)
geposted Mon 11 Sep 23 @ 8:35 am
@Groovindj
Appears that displayed tracks in the photo, are from duplicated tracks/folders, from OneDrive.
I don't know in what ways that may cause an issue, with the database on drive C.
geposted Mon 11 Sep 23 @ 7:38 pm
