Topic: Deactivate auto sync on load
Hello, this topic has been around a couple of times, but none to the solutions seems to help in my case:
When I load a song an press play, it will automatically sync to the one that is playing on the other deck (BPM and Beat).
I turned all the smart functions off. BPM Sync is off. Auto functions are off.
Quantize is off.
Still this happens...
I work on a Hercules Impulse 500. Everything else seems to be working great, only that is driving me CRAZY!
Any ideas anyone? Thanks in advance!
geposted Mon 28 Aug 23 @ 6:29 pm
If you havent modified the PLAY button on your Hercules, then all i can think of is...from VirtualDJ Settings ->OPTIONS tab..
- setting SmartPlay needs to be set to No
- setting autoBPMmatch needs to be set to No
Thank you for your reply!
I did not modify the play buttons. I checked the mapping already, to see if there is any additional function linked by default (which I wouldn't have assumed).
SmartPlay is OFF
Auto BMP Sync is OFF
I also reset the software to the standard settings last night. Didn't help.
Mind you, that if your controller has a "QUANTIZE" button and you turn quantize on, then it will also force BPM to sync (upon pressing the PLAY button) if the pitch range needed to sync the two decks is less than 10%
Holy s***, it is the quantise button! I read about it and tried it, but not carefully enough - obviously.
So when quantize is on, it syncs the BPM on play. can I deactivate that somehow? I thought, quantize only affects loops?
Anyway, THANKS A LOT!
globalquantize is in options just type it in the search box
For loops, just turn off quantize and turn on "smart_loop"
You can also turn on quantizesetloop option if you want the loop to not only snap in size (as with smart loop) but also to the grid
Please tell me, if you solved the problem. I have the same problem, I have already done everything as described. Does my Denon MC6000 MK2 also have a "quantizes" button?
I found globalquantoze and tried to exchange it to smart loop, but that is not really an option, cause it also basically reloops everything at the same time.
I would like the same behaviour, as e.g. in serato. Loops stick to the grid, and snapninsize, but tracks can be moved individually.
@beroj23 problem identified, working on a solution.
cool controller! But it doesn't have a Q Button, as far as I know.
You can turn Quantize off in the software though, or map a button.
But as you can read above, then your loops are off grid as well.
It certainly does not.
Smart Loop: When enabled, the loop out point of a loop is adjusted automatically so that the loop length is perfect in beats (e.g. 2 beats long, 4 beats long e.t.c.)
In other words it adjusts your timing error when pressing the loop out button.
Smart loop does NOT effect anything else. It does not sync tracks, it does not sync loops, it does not "lock" anything.
Quantize Loop: When enabled, the loop position is automatically adjusted on the grid based on globalQuantize value (in beats)
So, smart loop adjusts the length of the loop (by adjusting the loop out point) while quantize loop adjusts the position of the loop (by moving the entire loop) to be on the CBG.
Neither of these 2 functions adjusts BPM, or locks tracks together e.t.c.
Finally:
globalQuantize is a setting in beats. It tells VirtualDJ what fraction (or multiple) of a single beat it should use when performing quantized functions.
The "Quantize" button found on many controllers is using the "quantize_all" action which is an action, not a setting
So, I have been trying mapping this button in multiple ways now:
quantize_all does activate auto sync on play
smart_loop does it as well
quantize_loop does it as well
So when either of this functions is on, the second track will snap to the beat grid of the first one, adjust its bmp and therefore basically automatically syncs, as soon as I press play.
Can this function be linked in some way I am not aware of here?
also check out Klaus' awesome video 5 Levels of Sync
AND
UPADTE: I tried with a different controller, and everything there works just as you discribed or as I would have expected it to be. So apparently my controller just doesn't allow the global_quantize function to be off, no matter what boxed are checked.
Thank you all for your help!
